Введение
As this replacement guide works on an internal component of the Xoom Wifi, completion of prior steps to remove external parts is necessary.
  1. There are two 6.6mm screws that hold ports into place as well as the back panel. Remove these with a T-5 Torx screwdriver. There are two 6.6mm screws that hold ports into place as well as the back panel. Remove these with a T-5 Torx screwdriver.
    • There are two 6.6mm screws that hold ports into place as well as the back panel. Remove these with a T-5 Torx screwdriver.
  2. Apply light pressure with hand and slide the back plate till it stops in this position. There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove last two 4.2mm screws from the remaining back piece with a T-5 Torx screwdriver. Once both screws are taken out, lift the rest of the backing out of the way. Once both screws are taken out, lift the rest of the backing out of the way.
    • Remove last two 4.2mm screws from the remaining back piece with a T-5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  5. Use a plastic opening tool to pop out the speaker.  Make sure to carefully pull off the wire as well. Replace speaker if necessary.
    • Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
    • Replace speaker if necessary.
Заключение
Mallika
Участник с: 20.04.2014
461 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 3-39, Maness Spring 2014 Member of Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 членов
Автор 16 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 2
За всё время: 153
