Выберете то, что вам нужно
Use your sim card eject tool to remove the sim card and tray.
Using your heat gun or a hairdryer heat the back of the phone to loosen up the adhesive.
Now using your opening devices go along the edge of the phone slow and easy prying along the edges till they're loose.
As you're lifting up the back of your phone be sure you watch out for the fingerprint scanner, just keep it pushed down while you're lifting up the back of the phone .
Here you will have 15 t4 screws on top and bottom to take out but be careful with the top cover because the finger sensor runs under it. You don't want to rip that
Here we need to be careful that we don't damage the battery, so unhook the battery and its flex cable. Then carefully get one corner of the battery lifted up to where you can get a good grip to pull on it. You will have to pull it slower so you don't damage the battery once that is done you made it.
New line.
5 участников успешно повторили данное руководство.
