Motorola g stylus battery Replacement
Выберете то, что вам нужно
  1. Motorola g stylus battery Replacement, remove  the sims card and tray: шаг 1, изображение 1 из 2 Motorola g stylus battery Replacement, remove  the sims card and tray: шаг 1, изображение 2 из 2
    • Use your sim card eject tool to remove the sim card and tray.
  2. Motorola g stylus battery Replacement, remove stylus: шаг 2, изображение 1 из 1
    • Remove your stylus pen from the phone.
  3. Motorola g stylus battery Replacement, removing the back of your phone: шаг 3, изображение 1 из 3 Motorola g stylus battery Replacement, removing the back of your phone: шаг 3, изображение 2 из 3 Motorola g stylus battery Replacement, removing the back of your phone: шаг 3, изображение 3 из 3
    • Using your heat gun or a hairdryer heat the back of the phone to loosen up the adhesive.
    • Now using your opening devices go along the edge of the phone slow and easy prying along the edges till they're loose.
    • As you're lifting up the back of your phone be sure you watch out for the fingerprint scanner, just keep it pushed down while you're lifting up the back of the phone .
  4. Motorola g stylus battery Replacement, top and botttom inside covers: шаг 4, изображение 1 из 2 Motorola g stylus battery Replacement, top and botttom inside covers: шаг 4, изображение 2 из 2
    • Here you will have 15 t4 screws on top and bottom to take out but be careful with the top cover because the finger sensor runs under it. You don't want to rip that
  5. Motorola g stylus battery Replacement, Removing the battery: шаг 5, изображение 1 из 1
    • Here we need to be careful that we don't damage the battery, so unhook the battery and its flex cable. Then carefully get one corner of the battery lifted up to where you can get a good grip to pull on it. You will have to pull it slower so you don't damage the battery once that is done you made it.
    • New line.
Заключение
5 участников успешно повторили данное руководство.
Trent Weaver
Участник с: 09/16/20
232 Репутация
1 руководство автора
Один комментарий
Yessir, you the man bro
0% 100% - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 12
За последние 30 дней: 99
За всё время: 7,534
