Motorola i710 Keypad Cover Replacement
Выберете то, что вам нужно
  1. Motorola i710 Keypad Cover Replacement, Battery Cover: шаг 1, изображение 1 из 2 Motorola i710 Keypad Cover Replacement, Battery Cover: шаг 1, изображение 2 из 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Keypad Cover Replacement, Battery: шаг 2, изображение 1 из 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Keypad Cover Replacement, Back Casing: шаг 3, изображение 1 из 3 Motorola i710 Keypad Cover Replacement, Back Casing: шаг 3, изображение 2 из 3 Motorola i710 Keypad Cover Replacement, Back Casing: шаг 3, изображение 3 из 3
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
  4. Motorola i710 Keypad Cover Replacement, Motherboard: шаг 4, изображение 1 из 3 Motorola i710 Keypad Cover Replacement, Motherboard: шаг 4, изображение 2 из 3 Motorola i710 Keypad Cover Replacement, Motherboard: шаг 4, изображение 3 из 3
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
  5. Motorola i710 Keypad Cover Replacement, Keypad Sensor: шаг 5, изображение 1 из 2 Motorola i710 Keypad Cover Replacement, Keypad Sensor: шаг 5, изображение 2 из 2
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
  6. Motorola i710 Keypad Cover Replacement, Keypad Cover: шаг 6, изображение 1 из 2 Motorola i710 Keypad Cover Replacement, Keypad Cover: шаг 6, изображение 2 из 2
    • Once the keypad has been removed, the keypad cover can be easily peeled back from the front phone cover molding.
    • Care must be taken when inserting a new keypad cover. The keypad cover will have to be lined up to the corresponding holes of the phone casing.
Заключение
Katelyn
Участник с: 10/22/12
1 Репутация
Автор 2 руководств
Команда
Clemson, Team 14-2, Benson Fall 2012 Участник Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 членов
Автор 17 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 343
