Введение
Replace the speaker in the phone.
Выберете то, что вам нужно
Open the flip cover of the phone with the LCD screen facing towards you.
Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
Partially close the flip cover of the phone in order to take off the outer case.
Place your thumb underneath the protective metal covering to remove it from the phone.
Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
Insert the new speaker into the phone and it should look like the image at left.
