Motorola i886 Slide-out Keyboard Replacement
Выберете то, что вам нужно
  1. Motorola i886 Slide-out Keyboard Replacement, Back Cover: шаг 1, изображение 1 из 2 Motorola i886 Slide-out Keyboard Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Undo the headphone jack and USB port cover with your fingertip. Place your middle finger in the indent on the upper left side of the back of the phone.
  2. Motorola i886 Slide-out Keyboard Replacement, Open: шаг 2, изображение 1 из 1
    • Pull back until cover is removed. Place cover aside.
  3. Motorola i886 Slide-out Keyboard Replacement, Battery: шаг 3, изображение 1 из 1
    • Locate battery and use your index finger to grasp the upper left side of the battery and pull back to remove. Set battery aside.
  4. Motorola i886 Slide-out Keyboard Replacement, SIM Card: шаг 4, изображение 1 из 1
    • Locate and use your thumb to slide the SIM card to the right until it is removed and set it aside.
  5. Motorola i886 Slide-out Keyboard Replacement, Screw Removal: шаг 5, изображение 1 из 2 Motorola i886 Slide-out Keyboard Replacement, Screw Removal: шаг 5, изображение 2 из 2
    • Remove eight black .4 centimeter screws on the top, bottom, and sides of the phone with a T5 Torx screwdriver by inserting it into the screws and turning it to the left. Set screws aside.
  6. Motorola i886 Slide-out Keyboard Replacement, Separating: шаг 6, изображение 1 из 1
    • Loosen four fastener pieces on the side and bottom with a plastic opening tool to pry them backwards.
    • Insert the plastic opening tool between the loosened casing and the rest of the phone and pry the two pieces apart to remove the casing.
  7. Motorola i886 Slide-out Keyboard Replacement: шаг 7, изображение 1 из 1
    • Remove the .3 centimeter silver screw with the T5 Torx screwdriver.
    • Use your fingertips to lift up the circuit board and lay it on the side of the phone. Note that the two pieces are attached by a gold and black strip.
  8. Motorola i886 Slide-out Keyboard Replacement, Keyboard Removal: шаг 8, изображение 1 из 1
    • Locate and grip the black, white, and blue keyboard layer with your fingernail, lift up to remove it.
Заключение
Felicita Correa
Участник с: 09/03/14
418 Репутация
Автор 4 руководств
Команда
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014 Участник USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014
USFSM-STEWART-F14S1G2
3 членов
Автор 17 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 13
За всё время: 223
