Введение
Before proceeding with the replacement guide, please ensure the headphones are unplugged from any device.
Запчасти
  1. Remove leather headphone cushion by pulling edge towards middle of headphone.
    • Remove leather headphone cushion by pulling edge towards middle of headphone.
    • It should slip off the device.
  2. Carefully peel back foam pad to prevent tearing.
    • Carefully peel back foam pad to prevent tearing.
    • It is glued at both the top and bottom.
  3. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  4. Use the T6 torx screwdriver to remove the three screws holding the speaker in place.
    • Use the T6 torx screwdriver to remove the three screws holding the speaker in place.
    • To avoid stripping screws, be sure to use the right screw bit oriented perpendicular to the face of the screw.
  5. With the speaker removed from the speaker module, clip the black and white wires on the back of the speaker, as shown.
    • With the speaker removed from the speaker module, clip the black and white wires on the back of the speaker, as shown.
    • Solder wires onto corresponding pads of replacement speaker.
    • For soldering see the ifixit soldering guide: How To Solder and Desolder Connections
Заключение
John Ware
Участник с: 24.02.2014
325 Репутация
Автор 2 руководств
Команда
Michigan Tech, Team 5-1, Lauer Spring 2014 Member of Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
2 членов
Автор 3 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 227
