Введение
This guide is for those looking to replace their brake lever assembly on a mountain bike. It is a fairly simple task that does not require much prior bike knowledge. It only requires a 5mm Allen key, the lever assembly, isopropyl alcohol, and the bike.
Выберете то, что вам нужно
Using a 5mm allen key, loosen the lever assembly from the handle.
Slide the assembly off of the handle.
Pour a light amount of isopropyl alcohol through your grip and slide it back onto the handle.
Line up your lever assembly back into place.
Tighten the screw with the allen key to secure it.
Install the brake cable into the lever housing.
Take the brake cable and feed it into the lever pull.
Feed the cable into the lever assembly slot and through the barrel adjuster.
Use the barrel adjuster to tighten the cable intro place.
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
Еще один человек закончил это руководство.
