Mpow MPBH063 Motherboard Replacement
Выберете то, что вам нужно
  1. Mpow MPBH063 Motherboard Replacement, Battery: шаг 1, изображение 1 из 3 Mpow MPBH063 Motherboard Replacement, Battery: шаг 1, изображение 2 из 3 Mpow MPBH063 Motherboard Replacement, Battery: шаг 1, изображение 3 из 3
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
  2. Mpow MPBH063 Motherboard Replacement: шаг 2, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Купить
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
  3. Mpow MPBH063 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
    • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
    • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
  4. Mpow MPBH063 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
  5. Mpow MPBH063 Motherboard Replacement, Motherboard: шаг 5, изображение 1 из 1
    • Unplug all wires that are connected to the motherboard.
  6. Mpow MPBH063 Motherboard Replacement: шаг 6, изображение 1 из 2 Mpow MPBH063 Motherboard Replacement: шаг 6, изображение 2 из 2
    Купить
    • Detach the motherboard from the speaker using the tech knife and the adhesive remover to remove the adhesive securing the motherboard.
    • Use iFixit Adhesive Remover as directed.
    • Use the precision tweezers with the blunt head to carefully grip and pull out the motherboard.
    • Proceed with caution when using the tech knife and removing the motherboard as you do not want to cause injury to yourself or the device.
Заключение
Lianna Cook
Участник с: 10/09/18
248 Репутация
Автор 2 руководств
Команда
Sam Houston State, Team S15-G5, Blackburne Fall 2018 Участник Sam Houston State, Team S15-G5, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G5
3 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 1,773
