Введение
There are two O-rings in the Mr. Coffee BVMC-SJX33GT; If your coffee maker is leaking, the O-rings may potentially be damaged in some way and in need of replacement.
Make sure your coffee maker is unplugged and empty of all water before attempting to make any repairs.
Выберете то, что вам нужно
Locate the seven 13.5mm screws securing the base to the coffee maker.
Unscrew the screws using a #2 Phillips head screwdriver.
Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
Locate the metal clamps.
Using a pair of pliers or your fingers, slide clamps away from tube opening.
Using a plastic opening tool, loosen rubber hose from metal tubing.
Once loosened, grip the hose and pull it from the metal tubing.
Locate the other set of metal clamps.
Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
Locate the two 17mm screws securing the bracing bar.
Unscrew the screws with a #2 Phillip's head screwdriver and remove the bracing bar
Using a finger to keep the heating plate in place, grip the metal tubing and gently pull it away from the plate.
Set the metal tubing aside.
Locate the five 11.5mm screws securing the plastic ring to the coffee maker.
Unscrew the screws using a #2 Phillip's head screwdriver.
Gripping the plastic ring, pull it free from the coffee maker.
Flip the plastic ring over.
Еще один человек закончил это руководство.
