Введение
If your coffee maker is experiencing power issues, you may have a faulty power cord. Use this guide to replace the damaged power cord of your Mr. Coffee BVMC-SJX33GT.
Make sure your coffee maker is unplugged and empty of all water before attempting to make any repairs.
Выберете то, что вам нужно
Locate the seven 13.5mm screws securing the base to the coffee maker.
Unscrew the screws using a #2 Phillips head screwdriver.
Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
Locate the metal clamps.
Using a pair of pliers or your fingers, slide clamps away from tube opening.
Using a plastic opening tool, loosen rubber hose from metal tubing.
Once loosened, grip the hose and pull it from the metal tubing.
Locate the other set of metal clamps.
Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
Locate the two 11.5mm screws securing the plastic bracket in place.
Unscrew the screws using a #2 Phillip's head screwdriver and remove the bracket.
Locate the 11.5mm screw below the white, red, and blue wires. The screw is along the side of the coffee maker about four inches deep from the edge of the base.
Unscrew the screw with a #2 Phillip's head screwdriver and remove.
While maintaining a firm grip on the connector box, use needle nose pliers to pull the black wires free from the box.
Turn coffee maker around so that the back is facing you.
Pull the cord out through the back window.
