Выберете то, что вам нужно
Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
Twist warming plate clockwise so that the tab is out of place. Remove warming plate.
Почти готово!
Заключение
