Введение
To complete this repair you will need pilers, a Philips head screwdriver, and a flathead screw driver. During this repair you will remove the base of the coffee machine, loosen the support bar, before finally removing the heating plate and prying out the O-ring.
Запчасти
Никакие детали не требуются.
  1. Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean. Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver. Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Gently lift the base cover to expose the inside of the coffee machine.
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver. Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
    • Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
  5. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Gently lift the silver support bracket freeing the heating plate from the heating coil.
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
  7. Use needle-nose pilers to pinch and loosen the crimps Use needle-nose pilers to pinch and loosen the crimps
    • Use needle-nose pilers to pinch and loosen the crimps
  8. Once the crimps are loosened, slide them down the tubing.
    • Once the crimps are loosened, slide them down the tubing.
  9. Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart. Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
  10. Place one of your hands on the front side of the heating plate. Use this hand to gently push the heating plate towards yourself and out of the machine.
    • Place one of your hands on the front side of the heating plate.
    • Use this hand to gently push the heating plate towards yourself and out of the machine.
  11. Use a 2.5 mm Flathead Screwdriver to pry out the O-ring. Use a 2.5 mm Flathead Screwdriver to pry out the O-ring.
    • Use a 2.5 mm Flathead Screwdriver to pry out the O-ring.
Заключение
3 участников успешно повторили данное руководство.
Madeline Landis
Участник с: 21.01.2014
122 Репутация
1 Guide authored
Команда
Cal Poly, Team 10-31, Maness Winter 2014 Member of Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 685
