Mr. Coffee TF6 Internal Water Tubes Replacement
Выберете то, что вам нужно
  1. Mr. Coffee TF6 Internal Water Tubes Replacement, Bottom Cover: шаг 1, изображение 1 из 1
    • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  2. Mr. Coffee TF6 Internal Water Tubes Replacement: шаг 2, изображение 1 из 2 Mr. Coffee TF6 Internal Water Tubes Replacement: шаг 2, изображение 2 из 2
    • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  3. Mr. Coffee TF6 Internal Water Tubes Replacement: шаг 3, изображение 1 из 1
    • Gently lift the bottom cover, detaching it from the main body of the TF6.
  4. Mr. Coffee TF6 Internal Water Tubes Replacement, Internal Water Tubes: шаг 4, изображение 1 из 1
    • Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the metal tubing on the TF6.
  5. Mr. Coffee TF6 Internal Water Tubes Replacement: шаг 5, изображение 1 из 1
    • Carefully pull the silicon tubing off of the metal tubing.
  6. Mr. Coffee TF6 Internal Water Tubes Replacement: шаг 6, изображение 1 из 1
    • Using a Phillips #1 screwdriver, remove the three 13mm Phillips screws that hold the lower and upper assemblies together.
  7. Mr. Coffee TF6 Internal Water Tubes Replacement: шаг 7, изображение 1 из 1
    • Gripping the lower assembly with one hand and the upper assembly with the other, gently pull the assemblies apart.
    • If all screws have been removed and the tubes have been detached, the assemblies should separate easily.
  8. Mr. Coffee TF6 Internal Water Tubes Replacement: шаг 8, изображение 1 из 1
    • Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the plastic tubes on the upper assembly.
  9. Mr. Coffee TF6 Internal Water Tubes Replacement: шаг 9, изображение 1 из 1
    • Carefully pull the silicon tubing off of the plastic tubing on the upper assembly.
Заключение
Еще один человек закончил это руководство.
Jordan
Участник с: 01/31/14
204 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 13-18, Regan Winter 2014 Участник Cal Poly, Team 13-18, Regan Winter 2014
CPSU-REGAN-W14S13G18
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 15
За всё время: 1,643
