Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
Gently lift the bottom cover, detaching it from the main body of the TF6.
Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the metal tubing on the TF6.
Carefully pull the silicon tubing off of the metal tubing.
Using a Phillips #1 screwdriver, remove the three 13mm Phillips screws that hold the lower and upper assemblies together.
Gripping the lower assembly with one hand and the upper assembly with the other, gently pull the assemblies apart.
Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the plastic tubes on the upper assembly.
Carefully pull the silicon tubing off of the plastic tubing on the upper assembly.
Еще один человек закончил это руководство.
