Введение
Brake pads tend to wear down with use over time. Use this guide if you feel your brake pads have worn down enough that a replacement is necessary.
Выберете то, что вам нужно
When installing the new brake shoe, make sure it is properly aligned so it is in full contact with the edge of the rim.
To install your new brake shoes, follow these instructions in reverse order.
Еще один человек закончил это руководство.
