Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If you have a broken pedal or desire pedal clips this guide will assist you in removing and replacing your pedals.
Выберете то, что вам нужно
Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
Locate the 15mm pedal nut, and position the crank arms for maximum leverage.
Using a 15mm open-end wrench, brace the opposite pedal with your other hand and remove the pedal nut from the crank arm.
To install new pedal, follow these instructions in reverse order.
