Введение
This replacement guide is useful for someone who needs to replace a damaged rear derailleur for a Mt Fury Roadmaster.
Выберете то, что вам нужно
Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
Locate and remove the rear phillips head screw on the sprocket to remove one side of chain guard.
Rotate the derailleur arm forward to access the phillips head screw from the forwardmost sprocket. Remove the screw.
Be careful to hold the chain guard in place so the sprocket and washers don't fall out. (Chain guard is highlighted in red).
Loosen the shifting cable tension adjustment nut and remove the cable from the derailleur assembly .
To install new derailleur, follow these instructions in reverse order.
6 участников успешно повторили данное руководство.
2 Комментариев
Directions are simple clear and to the point. Excellent!
Now how do you put it back?
