Выберете то, что вам нужно
Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
Pry the cube face from the frame.
After removing the square plates, you can unscrew the screws underneath.
Remove four 6 mm Phillips #2 screws, located on the sides.
Remove twenty-four 6 mm Phillips #2 from all 6 sides.
Once the screws are removed, gently pull apart the frame.
Locate frame piece with battery pack and on-off switch, then remove two 6 mm Phillips #2 screws, located on either side of the battery pack.
Once removed, the on-off switch will easily slide out of position
To disconnect the on-off switch, carefully desolder the connecting points and remove the switch.
Place the new switch into position, and solder back into place.
To reinstall the switch, first place it back into position.
Insert the battery pack back into facing the correct way back into int battery pack slot.
Lastly, using the Phillips head screw driver to screw the screws back into place.
