Выберете то, что вам нужно
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
Use the slim plastic opening tool to pry the camera from its initial position.
Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
Use the slim plastic opening tool to remove the speaker from its position on the case.
Locate the red and black wires that connect the speaker to the motherboard.
Un-solder the red and black speaker wires that are connected to the motherboard
Remove the two screws that hold the volume button assembly in place.
Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
Use the wide plastic opening tool to slowly pry each side of the battery up.
Carefully lift up the motherboard. Your accessory parts such as battery, speaker, volume button assembly, and camera wires will be disconnected, not connected, like in this picture.
