Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
The batteries are located in the handle of the blaster.
The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
