Введение
If the speakers not working, or they are only making a static noise, then replacing them will fix the sound of the NABI XD.
Выберете то, что вам нужно
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
Go around the NABI XD and separate the rear panel from the device.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
Lift the charging port from the NABI XD.
Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
To disconnect antenna wire, use the tweezers to pry connector straight from the board.
Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
Right (R) speaker removal:
Remove one 4mm Phillips screw.
Use the metal spudger to separate the speaker from the frame.
Remove the left (L) speaker wire from the frame by pulling it to the side and up.
Left (L) speaker removal:
Remove two 4mm Phillips screws.
