Введение
Removing the antenna will allow you access to other parts of the device or it can replace the antenna if it is not working properly.
Выберете то, что вам нужно
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to gently pull the metal bracket that connects the antenna to the motherboard.
Find the clips that hold the antenna onto the router.
Use one hand to push the clips in, while using your other hand to pull out the antenna. You may need to gently twist the antenna so it can separate from the hole.
The antenna may take considerable force to remove.
