Введение
Removing the motherboard will allow you to replace it, or give you access to the other components that are attached to it.
Выберете то, что вам нужно
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Еще один человек закончил это руководство.
