Введение
This guide will help the user remove the gold tray handle with a screwdriver if the handle breaks or if you wish to replace it with a different piece. Make sure the machine is unplugged and off before proceeding.
Выберете то, что вам нужно
Unplug the machine and tilt the machine on its side with the pull out tray facing up.
With the Phillips #1 screwdriver, unscrew and remove the two , 12mm screws on the outside edges of the pull out tray as indicated. If you find difficulty unscrewing, WD-40 should help.
