NZXT H510i ATX Mid Tower Power Supply Replacement
Выберете то, что вам нужно
  1. NZXT H510i ATX Mid Tower Power Supply Replacement, Power Supply: шаг 1, изображение 1 из 2 NZXT H510i ATX Mid Tower Power Supply Replacement, Power Supply: шаг 1, изображение 2 из 2
    • Shut down the computer.
  2. NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 2, изображение 1 из 2 NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 2, изображение 2 из 2
    • Turn off the computer using the switch on the power supply. Unplug the power cable from the power supply.
    • This step is very important. Otherwise the computer will still be powered and it could damage its components or get you an electrical shock.
  3. NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Anti-Static Wrist Strap
    $7.95
    Купить
    • Drain the capacitors by pressing the power switch.
    • Wait several minutes after doing this to ensure that the capacitors are drained of all residual power.
    • Put on the anti-static wrist strap.
    • Caution: This step is crucial in order to avoid personal injury and damage to the computer from electrical discharge.
  4. NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 4, изображение 1 из 1
    • Remove the side panel by unscrewing the captive thumb screws keeping it in place. There will be one towards the top of the panel and another towards the bottom.
  5. NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 5, изображение 1 из 1
    • Identify the old power supply that will be replaced. As shown, it should be towards the bottom of the case, and towards the back of the computer.
    • Take a picture of how the cables are arranged so that this can be replicated later.
  6. NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 6, изображение 1 из 3 NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 6, изображение 2 из 3 NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 6, изображение 3 из 3
    • Unplug the various power cables. These include the Mainbords big 24 pin cable, the processor's power cable, the graphics card power cable, the SATA cables for the fan control, and the motherboard's power cable
  7. NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 7, изображение 1 из 3 NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 7, изображение 2 из 3 NZXT H510i ATX Mid Tower Power Supply Replacement: шаг 7, изображение 3 из 3
    • Using a Phillips #0 screwdriver, remove the four 6-32 x 6mm screws attached to the power supply.
    • Remove the old power supply from the case.
Заключение
6 участников успешно повторили данное руководство.
Graeme McCord
Участник с: 10/08/20
307 Репутация
1 руководство автора
Команда
University of Memphis, Team S3-G16, Willis Fall 2020 Участник University of Memphis, Team S3-G16, Willis Fall 2020
UM-WILLIS-F20S3G16
1 член
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 36
За последние 30 дней: 109
За всё время: 4,137
