Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
Using a spudger, slide the brown tab forward on each side of the connector
Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
If the screen is not working correctly, you will need to replace the entire display assembly
6 участников успешно повторили данное руководство.
3 Комментариев
Is the LCD glued to the front glass/digitizer?
It Worked Thank U So Much!!!
