Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
Use the spudger to pop the battery out of place and set it aside.
Desolder the battery connection and remove the battery completely
Note the color order for future replacemement
4 участников успешно повторили данное руководство.
3 Комментариев
Was hoping you could provide the replacement part number for this battery.
It shows on the picture: 1ICP6/68/112
Zoltan -
Hi,
where i can buy this replacement battery?
Thanks
