Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Some users of the tablet have faced problems with their headphone jack. If the headphone jack is not working, this repair guide can be used to remove and replace it. Please note that this guide should be used if cleaning the headphone jack fails to resolve your audio problems.
It is important to note that this guide will involve soldering and desoldering. When soldering, make sure that you do not touch any metal parts of the soldering iron. It gets very hot, very quickly.
Выберете то, что вам нужно
With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
Using a spudger, slide the brown tab forward on each side of the connector
Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
If the screen is not working correctly, you will need to replace the entire display assembly
Desolder the battery connection and remove the battery completely
Note the color order for future replacemement
Using the soldering iron, detach the speaker's wires from the circuit board.
Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
Desolder the six pins attaching the headphone jack to the motherboard
Remove headphone jack from motherboard
