Введение
This guide will aid you in the process of removing the screen of the device. This is useful in replacing broken screen.
Выберете то, что вам нужно
Make sure the screen is facing away from you and the back cover is facing you.
Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
After the back case is loosened, remove it from the device to change or access the battery.
Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the 4mm screws in a counter-clockwise rotation.
Pull motherboard away from the plastic.
Grip the screen and slide it out from between the plastic and the circuit board.
3 участников успешно повторили данное руководство.
