Nabi 2S Speakers Replacement
Выберете то, что вам нужно
  1. Nabi 2S Speakers Replacement, Nabi 2S Disassembly: шаг 1, изображение 1 из 1
    • Remove the red rubber case from the device.
  2. Nabi 2S Speakers Replacement: шаг 2, изображение 1 из 2 Nabi 2S Speakers Replacement: шаг 2, изображение 2 из 2
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Speakers Replacement: шаг 3, изображение 1 из 1
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Speakers Replacement: шаг 4, изображение 1 из 1
    • After the back case is loosened, remove it from the device to change or access the battery.
  5. Nabi 2S Speakers Replacement, Speakers: шаг 5, изображение 1 из 2 Nabi 2S Speakers Replacement, Speakers: шаг 5, изображение 2 из 2
    • Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the 4mm screws in a clockwise rotation.
  6. Nabi 2S Speakers Replacement: шаг 6, изображение 1 из 2 Nabi 2S Speakers Replacement: шаг 6, изображение 2 из 2
    • The speakers are attached to the device via wires that are connected to a circuit. Grasp the circuit connected to the right speaker.
    • Slide the connected wires from the circuit to detach the speakers.
  7. Nabi 2S Speakers Replacement: шаг 7, изображение 1 из 3 Nabi 2S Speakers Replacement: шаг 7, изображение 2 из 3 Nabi 2S Speakers Replacement: шаг 7, изображение 3 из 3
    • Lift the circuit board to get better access for removing the speaker.
    • Grasp the speaker with your fingers and lift it from the plastic
  8. Nabi 2S Speakers Replacement: шаг 8, изображение 1 из 2 Nabi 2S Speakers Replacement: шаг 8, изображение 2 из 2
    • Repeat steps 6 and 7 for the second speaker on the left side.
    • The circuit board should still be loose to remove the speaker.
Заключение
3 участников успешно повторили данное руководство.
Riana Ramirez
Участник с: 03/07/16
680 Репутация
Автор 4 руководств
Команда
Marist, Team 1-4, Laflen Spring 2016 Участник Marist, Team 1-4, Laflen Spring 2016
MARS-LAFLEN-S16S1G4
2 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 250
