Введение
This guide will aid you in the process of removing the speakers of the device. This is useful in replacing broken speakers
Выберете то, что вам нужно
Make sure the screen is facing away from you and the back cover is facing you.
Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
After the back case is loosened, remove it from the device to change or access the battery.
Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the 4mm screws in a clockwise rotation.
The speakers are attached to the device via wires that are connected to a circuit. Grasp the circuit connected to the right speaker.
Slide the connected wires from the circuit to detach the speakers.
Lift the circuit board to get better access for removing the speaker.
Grasp the speaker with your fingers and lift it from the plastic
3 участников успешно повторили данное руководство.
