Выберете то, что вам нужно
Remove the red rubber case from the device. This should come off with ease.
Turn the device so the screen is facing away from you.
Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
After loosening the back cover, remove it from the device so you can get at the innards.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers remove tape that connects the board to the camera's ribbon cable.
Lift the slot's locking tab up to easily remove the ribbon cable from the board.
Place the new camera piece in place of the old and plug its ribbon cable back into the respective slot on the board.
Make sure the locking tab on the slot is in its up position before inserting tape.
Once the tape is inserted press the locking tab back to its down position to securely fasten the ribbon cable.
