Выберете то, что вам нужно
Remove the red rubber case from the device. This should come off with ease.
Turn the device so the screen is facing away from you.
Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
After loosening the back cover, remove it from the device so you can get at the innards.
The speakers are located near the top of the device close to the camera.
Using a desoldering tool, remove the speakers from the pads they are soldered to.
Solder the new speaker's wires onto their respective pads
