Введение
Follow these steps to remove or replace a dead battery from your Neato Botvac D8000.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to unscrew both of the 20mm screws.
Gently lift the battery cover.
Remove the battery cover to reveal the battery.
Use a flathead screwdriver to push down on the latch of the battery clip.
Simultaneously, pull on the battery while pushing down on the latch to detach the battery from the clip.
Еще один человек закончил это руководство.
