Necklace Barrel Clasp Repair
Выберете то, что вам нужно
  1. Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: шаг 1, изображение 1 из 2 Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: шаг 1, изображение 2 из 2
    • Locate the broken part of the ring that attaches through the back of the barrel clasp.
    • Bend the portion of the ring with needle nose pliers until the newly compact ring can be pushed through the barrel clasp and fit snug.
  2. Necklace Barrel Clasp Repair: шаг 2, изображение 1 из 1
    • Plug in the electric soldering iron and set the solder temperature to the degrees that suits the melting point of both the soldering wire and the barrel clasp.
    • The soldering iron tip can get extremely hot and will cause severe burns if comes into direct contact with skin. Ensure you keep a safe distance, and wear safety equipment.
    • This method is not recommended for precious metals.
  3. Necklace Barrel Clasp Repair: шаг 3, изображение 1 из 1
    • Molten metal is extremely hot and will cause severe burns. Handle the soldering gun with care and keep your distance from the melting metal.
    • Solder the base of the barrel clasp where the metal ring fits in, intersecting the tips of the soldering gun and soldering wire.
    • Ensure the barrel clasp and ring connection is covered, allowing anywhere from 10 to 30 seconds for the bond to harden and cool.
  4. Necklace Barrel Clasp Repair: шаг 4, изображение 1 из 1
    • Attach the barrel clasp necklace back together and hold each end of the necklace taught to test the solder strength.
    • Do not pull too hard—the amount of strain may cause the solder to break.
Заключение
Garrett Key
Участник с: 07/12/17
110 Репутация
1 руководство автора
Команду
Texas Tech, Team S1-G5, Rauch Summer 2017 Участник Texas Tech, Team S1-G5, Rauch Summer 2017
TTU-RAUCH-SU17S1G5
3 членов
Автор 1 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 10
За последние 30 дней: 26
За всё время: 2,933
