Выберете то, что вам нужно
Turn the Neo3DO face down so that the logo is facing toward you.
Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
Grip the active(red) wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
Repeat the same process to remove the neutral(black) wire.
Use the flat end of the plastic spudger to remove the motherboard and turn it underside-up.
Grip the wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
Using the plastic removal tool, lift the LED screen from the battery side, and use the tweezers to help lift the LED screen upwards.
Use the plastic removal tool to pry the audio PCB and pull away from the frame to remove it.
