Nerf Alpha Trooper CS-18 Plunger Replacement
Выберете то, что вам нужно
  1. Nerf Alpha Trooper CS-18 Plunger Replacement, Plunger: шаг 1, изображение 1 из 1
    • It is important to group screws together by length to ensure proper reassembly.
    • Be sure that the device has been discharged and is unloaded before beginning the repair process.
  2. Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 2, изображение 1 из 3 Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 2, изображение 2 из 3 Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 2, изображение 3 из 3
    • Look at the rear of the rifle. Remove the two 10 mm Phillips head screws that hold the black cap to the rear of the rifle.
    • Gently remove the black cap.
  3. Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 3, изображение 1 из 2 Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 3, изображение 2 из 2
    • Point the barrel of the device to the left, screw side up. Remove the two 8 mm Phillips head screws (the top two) holding the device slide together.
    • Keep the device in the same position, remove the three 10 mm Phillips head screws from the bottom of the device slide.
    • Once all screws are removed, carefully separate the two halves of the device slide and put them aside.
    • Be sure to keep track of which screws correspond to the correct holes.
  4. Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 4, изображение 1 из 3 Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 4, изображение 2 из 3 Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 4, изображение 3 из 3
    • Keeping the barrel in the same position as step 3, remove the fourteen 10 mm Phillips head screws from the body of the device.
    • With the device in the same position, remove the 4 remaining 5 mm Phillips head screws from the body of the device.
    • Screws vary in lengths. Be sure to keep track of which screws correspond to the correct holes.
  5. Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 5, изображение 1 из 3 Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 5, изображение 2 из 3 Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 5, изображение 3 из 3
    • Grip the cartridge insert, and pull the two halves of the device apart.
    • Warning! The firing spring is not fastened to the device. It and other small parts may fall out of the device when separating it.
    • If you are having difficulty separating the two halves of the device, use a spudger to pry the two halves apart.
    • Remove the access gate and barrel cover.
  6. Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 6, изображение 1 из 1
    • Now remove the main firing spring from the rear of the device by gently pulling it.
  7. Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 7, изображение 1 из 2 Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 7, изображение 2 из 2
    • Slide the plunger lock back away from the device, then lift out towards yourself to remove.
    • Be careful not to lose the small spring on the top of the plunger lock.
  8. Nerf Alpha Trooper CS-18 Plunger Replacement: шаг 8, изображение 1 из 1
    • Pull plunger away in the same motion as in step 7 with the plunger lock.
Заключение
Еще один человек закончил это руководство.
Chelsea Frazier
Участник с: 01/31/16
128 Репутация
1 руководство автора
Команда
University of Alabama, Team 1-1, Sydow campbell Spring 2016 Участник University of Alabama, Team 1-1, Sydow campbell Spring 2016
UA-SYDOW CAMPBELL-S16S1G1
4 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 1,856
