Nerf Dart Tag Furyfire Chamber Replacement
Выберете то, что вам нужно
  1. Nerf Dart Tag Furyfire Chamber Replacement, Remove the screws: шаг 1, изображение 1 из 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Chamber Replacement, Remove Panel: шаг 2, изображение 1 из 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Chamber Replacement, Remove Black Cylinder: шаг 3, изображение 1 из 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Chamber Replacement, Remove Spring: шаг 4, изображение 1 из 2 Nerf Dart Tag Furyfire Chamber Replacement, Remove Spring: шаг 4, изображение 2 из 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Chamber Replacement, Remove Pump Handle: шаг 5, изображение 1 из 1
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Chamber Replacement, Remove the Pump Handle: шаг 6, изображение 1 из 1
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Chamber Replacement, Remove Attached Spring: шаг 7, изображение 1 из 2 Nerf Dart Tag Furyfire Chamber Replacement, Remove Attached Spring: шаг 7, изображение 2 из 2
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Chamber Replacement, Disengage White Piece: шаг 8, изображение 1 из 1
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Chamber Replacement, Remove the Pump Track: шаг 9, изображение 1 из 2 Nerf Dart Tag Furyfire Chamber Replacement, Remove the Pump Track: шаг 9, изображение 2 из 2
    • Using your hand, slide the track out of the gun by pulling it away form the device.
  10. Nerf Dart Tag Furyfire Chamber Replacement, Detach Black Piece from Trigger: шаг 10, изображение 1 из 1
    • Using a plastic opening tool, detach the black piece from the trigger. You do not need to remove the black piece from the gun.
  11. Nerf Dart Tag Furyfire Chamber Replacement, Remove Trigger: шаг 11, изображение 1 из 1
    • Once the black piece has been detached, the trigger can be lifted out of the device.
  12. Nerf Dart Tag Furyfire Chamber Replacement, Remove Black Connector: шаг 12, изображение 1 из 1
    • Once the trigger has been removed, simply pull the black connector out of the chamber. Set it aside.
  13. Nerf Dart Tag Furyfire Chamber Replacement, Separate Barrel and Chamber from the Main Body: шаг 13, изображение 1 из 2 Nerf Dart Tag Furyfire Chamber Replacement, Separate Barrel and Chamber from the Main Body: шаг 13, изображение 2 из 2
    • With your hands gently grasp the barrel and chamber of the gun, and pull it away from the main body.
  14. Nerf Dart Tag Furyfire Chamber Replacement, Separate Barrel and Chamber: шаг 14, изображение 1 из 1
    • Using your hands, remove the barrel from the rotating chamber.
Заключение
Еще один человек закончил это руководство.
Bradley Penrow
Участник с: 09/23/14
37 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 11-2, Blackwell Fall 2014 Участник USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 1,072
