Nerf Dart Tag Furyfire Pump Track Replacement
Выберете то, что вам нужно
  1. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the screws: шаг 1, изображение 1 из 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Panel: шаг 2, изображение 1 из 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Black Cylinder: шаг 3, изображение 1 из 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: шаг 4, изображение 1 из 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: шаг 4, изображение 2 из 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Pump Handle: шаг 5, изображение 1 из 1
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Handle: шаг 6, изображение 1 из 1
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: шаг 7, изображение 1 из 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: шаг 7, изображение 2 из 2
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Pump Track Replacement, Disengage White Piece: шаг 8, изображение 1 из 1
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: шаг 9, изображение 1 из 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: шаг 9, изображение 2 из 2
    • Using your hand, slide the track out of the gun by pulling it away form the device.
Заключение
Еще один человек закончил это руководство.
Bradley Penrow
Участник с: 09/23/14
37 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 11-2, Blackwell Fall 2014 Участник USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 12
За всё время: 472
