Введение
This guide will help you find and replace the motor spring.
Инструменты
Запчасти
Детали не указаны.
Using the JIS #1 screwdriver, loosen the nine screws, holding the outer yellow shell in place
Remove the screw holding the battery compartment shut.
Lift off the inner blue casing
Lift off the blue casing, exposing the white motor spring compartment.
Loosen and remove the three screws holding the white compartment door shut.
Почти готово!
Заключение
