Выберете то, что вам нужно
Start by removing the (4) exterior Phillips screws from the shell of the gun with a #1 Phillips Screwdriver.
Pulling upward from the rest of the shell, carefully remove the half of the slide facing you.
Lift up on the top half of the shell with deliberate force. This should reveal the internals.
Locate the screws on the return spring. Using a counterclockwise rotation, remove both of the screws.
Locate the screws behind the dart pusher mechanism. Carefully remove each screw.
Lift the left side of the plunger tube from its peg and the rest will slide off the spring peg.
3 участников успешно повторили данное руководство.
