Введение
A damaged hammer rod may make it difficult, or entirely prevent the slide from operating. This can make loading the rifle difficult. This guide shows you how to access and replace the silver hammer rod next to the barrel of the Nerf gun.
Выберете то, что вам нужно
Be sure that the rifle is discharged and unloaded before starting disassembly.
Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
Pull off the orange cap.
With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
Separate and remove the two halves of the slide mechanism.
Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
Remove the two 5 mm phillips screws from the main body.
Remove the two 8 mm phillips screws from the main body.
Pull the two halves of the rifle apart.
Remove the access gate and barrel cover.
You should now be able to pull the main firing spring from the rear of the rifle.
Pull the front chamber lock spring up and out of its seat.
Pull the front chamber lock mechanism down and out of the rifle barrel.
Note there are two pieces to this mechanism.
Holding the rear chamber slide lock down, slide the chamber to the rear of the rifle.
Remove the rear section of the barrel.
With the plunger in the air cylinder, pull the plunger lock out of the rifle body.
While holding the slide lock mechanism down, pull the bullet chamber assembly up and out of the rifle.
Part of the magazine lock mechanism should come along with it.
With the hammer rod side of the bullet chamber facing you, unscrew the 5 mm phillips screw holding the hammer rod in place.
Еще один человек закончил это руководство.
