Введение
Keep your Nerf N-Strike Elite Hail-Fire running with new batteries.
Запчасти
No parts specified.
  1. Remove the two 9.0 mm Phillips screws from the battery compartment.
    • Remove the two 9.0 mm Phillips screws from the battery compartment.
  2. Pull the battery compartment out and away from the gun.
    • Pull the battery compartment out and away from the gun.
  3. Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
    • Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
  4. Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
    • Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
  5. When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
    • When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
Заключение
3 участников успешно повторили данное руководство.
Jonathan Peck
Участник с: 24.01.2014
169 Репутация
1 Guide authored
Команда
Cal Poly, Team 13-13, Regan Winter 2014 Member of Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 5
За 7 дней: 32
За 30 дней: 172
За всё время: 18,039
