Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the two 9.0 mm Phillips screws securing the battery compartment.
Slide the battery compartment out.
Remove the five 9.0 mm Phillips screws securing the trigger.
Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
Remove both halves of the ring by tugging on it upwards until the lock gets freed.
Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
Remove the three 9.0 mm Phillips screws holding together the firing chamber.
Remove the single 7.0 mm Phillips screw below the barrel.
Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
Remove the two 9.0 mm Phillips screws holding together the handle.
Remove the plastic cover of the handle.
Insert one plastic opening tool inside one side of the orange part depicted in the picture.
Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
Pull one end of the handle away from the orange latch.
Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
Completely remove the left shell from the rest of the Nerf Gun.
Еще один человек закончил это руководство.
