Введение
A damaged or obstructed barrel can greatly hinder your blaster’s performance. Follow the procedure to clean or replace the barrel.
Modifying your blaster is not advised and may void the manufacturer’s warranty in certain states.
This blaster is equipped with a rifled barrel for maximum performance.
Запчасти
No parts specified.
  1. While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
    • Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
    • This may require more force than anticipated.
  3. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  4. Disassemble the orange barrel cap by removing two 8mm Phillips screws.
    • Disassemble the orange barrel cap by removing two 8mm Phillips screws.
  5. Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
    • Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
    • There are springs that may become displaced when the barrel housing is removed. Proceed with caution.
  6. Remove the orange barrel from the assembly.
    • Remove the orange barrel from the assembly.
Заключение
3 участников успешно повторили данное руководство.
ericharman
Участник с: 02.03.2016
1 173 Репутация
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 2
За 7 дней: 25
За 30 дней: 122
За всё время: 5,409
