Введение
A worn plunging mechanism can limit your effective firing range. Nobody has time for that. Use this guide to disassemble the blaster and replace the plunger and air chamber.
Выберете то, что вам нужно
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
Remove white air chamber by depressing the orange trigger apparatus and pulling backwards off of the barrel.
16 участников успешно повторили данное руководство.
4 Комментариев
Where did we found the pièces??
where i can buy for spare part “air chamber”?
this tutorial helped A LOT
