Nerf N-Strike Elite Retaliator Case Disassembly
Выберете то, что вам нужно
  1. Nerf N-Strike Elite Retaliator Case Disassembly, Case Disassembly: шаг 1, изображение 1 из 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Case Disassembly: шаг 2, изображение 1 из 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Case Disassembly: шаг 3, изображение 1 из 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
    What about a drum mag how do you remove that
    Alex Leadbeater - Ответить
  4. Nerf N-Strike Elite Retaliator Case Disassembly: шаг 4, изображение 1 из 2 Nerf N-Strike Elite Retaliator Case Disassembly: шаг 4, изображение 2 из 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Case Disassembly: шаг 5, изображение 1 из 2 Nerf N-Strike Elite Retaliator Case Disassembly: шаг 5, изображение 2 из 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
    Itd be nice if we got a pic comparing the internals to an old yellow nerf recon (if you have one). I wonder how much changes between generations.
    sigoshi - Ответить
    Removed every screw and gun does not separate. not showing the seperation of the gun makes this tutorial completely useless.
    Jeff Glover - Ответить
    You have to remove the thing you use to ready it
    Daniel MacDonald -
    It would be nice if you could color-code where to put the 16mm, 10mm and 8mm screws. That way, you don’t wind up damaging the screw post or stripping a screw by trying to insert a 10mm screw into a post meant for an 8mm one.
    SirMikay - Ответить
    it's very helpful that the troubleshooting for slider won't move backwards goes to "Another two must be removed with the sliding mechanism in the back position." How, just how do you do that if it's jammed
    Adrian Tennies - Ответить
    please help if you can
    Adrian Tennies -
    definitely not angry at the troubleshooting page
    Adrian Tennies -
Финишная черта
28 участников успешно повторили данное руководство.
ericharman
Участник с: 03/02/16
1 410 Репутация
Автор 5 руководств
14 Комментариев
How do I clean the slider track?
devinwhaley - Ответить
you probably should not do that. i think its oily for a reason.
one smol birb -
You shouldn't. That oily substance is lubricant, which is crucial for smooth functionality.
SirMikay -
Mine had a chopped off dart head stuck in the trigger mechanism.
I had to partially disassemble in order to be able to free the slide which was covering 1 screw.
Overall, it was very easy. Only challenge is keeping track of the screws, as they're not all the same.
Pete Isaacs - Ответить
then why did u read it
shinyern -
Took it apart. Then had to throw it out…
acejohnstonmafiawars - Ответить
I couldn’t get the slider apart after removing the screws.
John H - Ответить
You have to remove ALL the screws in order to take the blaster apart. That means on both the priming handle and the blaster itself.
SirMikay -
how much is this gun cuase im gettting this for christmas
Elias Robinson - Ответить
I just had to realign the chamber guide that is on top of the magazine with a screw driver. To keep track of the screws I traced the gun first then mapped out where the screws went. When i removed them I placed them in the paper where the are in relation to the gun. Maps are fun!
Joseph Andreasson - Ответить
It would be nice if you could color-code the screw “map” so we know which length goes in what post. That way, we don’t ruin a post or strip the head of a screw by trying to fit a 10mm screw into an 8mm post and vice versa. You also might want to add that there is one screw that's well over 10mm long.
SirMikay - Ответить
How to disassembly NERF elite 2.0 echo Cs-10.?
Padma konagalla - Ответить
I am having trouble getting my slider all the way to the front.. There is no darts stuck in the place they shoot out, agh I am so confused and nothing seems to say why my slide won't go all the way forward.
Haillie Smith - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 42
За последние 30 дней: 181
За всё время: 34,882
