Введение
Moving components in your blaster can be accessed by removing the outer casing. This guide shows how to access these inner components.
Выберете то, что вам нужно
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
Removed every screw and gun does not separate. not showing the seperation of the gun makes this tutorial completely useless.
You have to remove the thing you use to ready it
it's very helpful that the troubleshooting for slider won't move backwards goes to "Another two must be removed with the sliding mechanism in the back position." How, just how do you do that if it's jammed
please help if you can
definitely not angry at the troubleshooting page
28 участников успешно повторили данное руководство.
14 Комментариев
How do I clean the slider track?
you probably should not do that. i think its oily for a reason.
You shouldn't. That oily substance is lubricant, which is crucial for smooth functionality.
SirMikay -
Mine had a chopped off dart head stuck in the trigger mechanism.
I had to partially disassemble in order to be able to free the slide which was covering 1 screw.
Overall, it was very easy. Only challenge is keeping track of the screws, as they're not all the same.
Boo this sucks
then why did u read it
shinyern -
Took it apart. Then had to throw it out…
how much is this gun cuase im gettting this for christmas
I just had to realign the chamber guide that is on top of the magazine with a screw driver. To keep track of the screws I traced the gun first then mapped out where the screws went. When i removed them I placed them in the paper where the are in relation to the gun. Maps are fun!
It would be nice if you could color-code the screw “map” so we know which length goes in what post. That way, we don’t ruin a post or strip the head of a screw by trying to fit a 10mm screw into an 8mm post and vice versa. You also might want to add that there is one screw that's well over 10mm long.
How to disassembly NERF elite 2.0 echo Cs-10.?
I am having trouble getting my slider all the way to the front.. There is no darts stuck in the place they shoot out, agh I am so confused and nothing seems to say why my slide won't go all the way forward.
