Введение
This guide is going to show you how to take apart the blaster to reach the spring that is located in cocking mechanism of the Nerf.
Выберете то, что вам нужно
Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
Once the screws have been removed, lift the top half of the gun off.
Take care and try not to lose any smaller pieces as you open it up.
Locking tab for attachments.
Remove the screw on the inside of the gun.
Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
Remove the barrel from the blaster.
Remove the front component from the blaster.
Both components do not need any tools to be removed.
First, remove the trigger.
Then remove the cocking holdback.
Then remove the air compressor chamber.
Locate and remove the indicated screw.
This is the spring controlling the cocking mechanism. If the spring is damaged, replace it.
17 участников успешно повторили данное руководство.
20 Комментариев
Where does the locking tab in step 5 go
on the top of the gun(Seeing from the position as if you're aiming)
Its only there for accesory so it still works if you don't return it
chanisco -
